Thread: Coolant temp
Created on: 04/29/15 04:02 PM
miket
miket's Gravatar
Coolant temp
04/29/15 4:02 PM
Ok two rides on bike . On highway temp at 2 or 3 bars got stuck behind school bus on my street fan on at three 4 min then parked in driveway left key on fan stayed on engine off now showing 5 bars normal behavior? 2009 2300 miles new to me dec20 14
* Last updated by: miket on 4/29/2015 @ 4:03 PM *
09 zx14 2000 miles black new to me
02 zrx 1200 r red way too much invested but I love this Bike!
83 gs 1100 red with es fairing again way too much$$$ Cleanist one I've seen
RE: Coolant temp
04/29/15 7:08 PM
Totally normal. That's very low miles. It may start to run a little bit cooler as it breaks in. I wouldn't count on much. Full system exhaust will reduce the temp some. It's just a hot running engine.
Perhaps you are aware of this but for anyone reading who might not be, letting the fan run after shutting down the engine won't cool the engine off. If the coolant isn't circulating, it can't cool anything but the radiator.
RE: Coolant temp
04/29/15 7:11 PM
I've seen 5 bars on mine. I have seen 6 bars a couple times and I think I even saw the overheat icon come on the meter a few minutes after shutting down when the bike was very new. Never had an overflow.
Wait until summer sets in. Trust me on the full system exhaust.
miket
miket's Gravatar
RE: Coolant temp
04/30/15 9:26 AM
Motor still has rubber condom
RE: Coolant temp
04/30/15 12:02 PM
If you're referring to the rubber piece over the top of the valve cover, it's there to dampen valve train noise and keep engine heat from heating the fuel any more than necessary. It has no effect on engine or coolant temperature, since that all takes place within the water jackets and radiator.
* Last updated by: Danno on 4/30/2015 @ 12:02 PM *
RE: Coolant temp
04/30/15 12:13 PM
I removed mine from the air box and the engine. No difference that I can tell.
RE: Coolant temp
04/30/15 1:20 PM
Miket, at anything below 40 mph my fan is on and my bars are at at least 4 if not 5. I've ridden it in 90+ temps and it's always the same. Never had an overflow, never had a warning. It's good to go.
RE: Coolant temp
04/30/15 2:58 PM
Mine rus on the highway about 3-4 bars. 2 if it is cold weather in springtime. I still might see 5 on a hot day 90° F if I am in stop and go traffic. That's with full system. That made it run almost a bar cooler in most situations.
JMSZX14
JMSZX14's Gravatar
RE: Coolant temp
09/13/15 11:24 AM
Blue ice ooolant and wrap the header pipes between the radiator and engine.
Has worked for my ZX14 in Houston TX. since 2008 100 DEGREE HEAT....
ENJOY.
JMSZX14 "TWIST THAT THROTTLE"
ApogeeNow
ApogeeNow's Gravatar
RE: Coolant temp
07/01/16 5:03 AM
After the build on my bike, my bike ran considerably hotter, although it never actually "overheated".
I then decided to add an auxiliary cooling fan, it made a huge difference.
Florida's summers' high heat and high humidity are very hard on motorcycles and riders both.
2007 Plasma Blue ZX-1464, 2mm Bore X 2mm Stroke (1464ccs), OER Hi-Mounted Full Exhaust System, Re-Flash, KN Air Filter, SpeedoHealer, Flies Out, FP Velocity Stacks, Under-Cut Gears, HotBodies Undertail, ZX14 Chain Guard, Cox Racing Radiator Guard, 600 amp Antigravity battery, Auxiliary cooling fan, HID Lights 6K-Lo / 8K Hi, Valentine Radar Detector
